Connect LVTTL to PIC
Re: Connect LVTTL to PIC
Postby shahrul » Mon Mar 19, 2012 3:08 pm
Now, I have successful interface SKM53 with PIC. This is the final circuit.
SKM53 Schematic.jpg (23.01 KiB) Viewed 4789 times
I have try remove R3, but it not works.
I have try use R4 = 330 ohm, but it not works.
I have try use R5 = 1k ohm, but it not works.
My finding, maybe the SKM53 have high internal impedance because it doesn't matching with low impedance load.
Postby robosang » Tue Mar 20, 2012 10:19 am
Weird for me to see that, anyway I don have the GPS module, cannot investigate further, :mrgreen:
Postby shahrul » Tue Mar 20, 2012 10:26 am
robosang WROTE:Weird for me to see that, anyway I don have the GPS module, cannot investigate further, :mrgreen:
I'm also weird, can't explain theoretically but this is practically :D
Postby takao21203 » Tue Mar 20, 2012 12:10 pm
Have you tried PNP transistor (2n3906)?
takao21203
Postby shahrul » Tue Mar 20, 2012 12:14 pm
takao21203 WROTE:Have you tried PNP transistor (2n3906)?
No, maybe on next project.
Postby waiweng83 » Fri Mar 23, 2012 10:59 am
Hi Shahrul,
I'm facing the same problem with the LS20031 GPS module from Sparkfun. AFAIK, both LS20031 and SKM53 are using the same Mediatek MK3329 Chipset.
There is an easy fix to the problem, just change the R1 to higher value. I'm using 33k ohm for now, I think everything from 30K to 100k should work.
I got to know this fix by trial and error. I still can't figure out why the low resistance will halt the GPS module. :cry:
waiweng83
Postby shahrul » Fri Mar 23, 2012 11:21 am
waiweng83 WROTE:Hi Shahrul,
Hi Waiweng, thanks for the info. I will try later on next project. :)
Previous
